Mirror defrost light flashing/ no AC
Old Sep 24, 2014 | 08:56 PM
dakota19762's Avatar
dakota19762
Default Mirror defrost light flashing/ no AC
I had to unhook the ECM to replace the TCM on my 2002 ram 4.7. I now have the 5 speed transmission Problem is: when I reconnected the wires and battery, the ABS light was flashing and the mirror defrost light is flashing with no AC controls now.
I went to dealership and the ABS was reset and is working, but the tech said the cluster is not communicating with the computer. I tried a different cluster and the problem is still the same. I did research this and someone said that the ECM needs to be re-calibrated to make the AC work. Unfortunately neither of the Dodge techs knew what to do to fix it. They both did a reset on the AC system, but no change. I wasn't charged at either dealership because they could not fix the issue.
Does anyone know what needs to be done to fix this?
Old Sep 27, 2014 | 03:15 PM
dakota19762
Does anyone know how to contact Chrysler so I can try to find an answer. Someone must know how to fix this issue.
Old Sep 27, 2014 | 06:34 PM
p38251's Avatar
p38251
pm the dodge cares guy.
