Should I replace my front shock absorbers?
At first I thought it was my ball joints. Didn't replace them since I have not had time for an alignment. Today I changed the fluid in the rear diff and decided to troubleshoot a little more. I had someone stand in the bed of the truck and bounce the *** end up and down to make the truck rock. I laid under the front and listened and felt around and I seem to think it is my shock.
It squeaks when compressing and noticeable on backroads that aren't as level as smooth as in town roads. I am thinking this is probably the problem. Any insight to check anywhere else before I throw my money into hopefully fixing this problem? Also, would I need to get an alignment after changing them? I figured if one is bad might as well just replace both.
Thanks.
Thanks.
This question also has not been answered. will i need an alignment when I am finished with this?
Alignment not needed with just shocks. I'd do it anyways if you haven't yet. I take mine to Brake Check and get their Lifetime deal, so when I get new tires I can have it done.
SJ03
SJ03
Trending Topics
I was planning on doing just the front, Should do the rears too? And is there anyway to get a small 2inch lift or so out of doing this without spending a lot of money?
