Brake Light On
Old Oct 9, 2014 | 12:39 AM
M.A.D's Avatar
M.A.D
Default Brake Light On
Hey fellows, I have a 03 dodge ram laramie 1500 5.7 hemi. Mine brake light staying on while, the key switch is on. Once the key shut off brake light goes off. Turn on brake light stay on. Have anybody run into this problem. Was thinking about the brake light switch, but it's not the switch
Old Oct 9, 2014 | 07:28 AM
chuck_hammer's Avatar
chuck_hammer
bad brake light switch.. I had to replace mine this spring.. same issue...
its like 13.00 dollars... shop around... may be cheaper... I was out of state..
Old Oct 9, 2014 | 07:29 AM
SmokinJoe02's Avatar
SmokinJoe02
Is your fluid low?
SJ03
Old Oct 9, 2014 | 07:48 AM
Originally Posted by SmokinJoe02
Is your fluid low?
SJ03
This ^^ Have you checked anything at all yet?
Old Oct 9, 2014 | 05:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Likely the brake switch behind the brake pedal is stuck
