Last edit by: IB Advertising
Browse all: Electrical Guides
- Dodge Ram 2002-2008: Fuse Box Diagrams
Important information to help you understand your Ram
No power to half the fuse box
Id make sure that the mechanics who pulled the heads off which is quite an involved process, didnt damage the camshaft sensor wiring and any other parts of the electrical harness.
I know that's quite an undertaking, but you'd then know for sure, its nothing a nipped or damaged electrical wire is causing.
Al.
Al.
Hi, I didn't have time to replace the air intake sensor, but I did remove the crankshaft sensor and compare it to the old one. To me, they look identical. I attached a picture. Is there more to installing it than pulling the old one out and sticking the new one in?
One possibly significant issue I found while looking in the engine is the EGR valve and solenoid assembly is extremely loose. I can easily move it by hand. The tube that goes from the EGR valve to the intake manifold is also movable and is definitely not making a sealed connection to the intake manifold. Could this be my problem?
Check that out and let us know how you make out.
Finally got a chance to work on the truck again. I borrowed a compression tester from a local shop. Tried it on 4 separate cylinders, no compression in any one. Looks like I have a long and expensive weekend ahead of me. Hopefully, just a timing chain.
Time to pull the heads and check the timing chain (which I'm assuming broke)... if it didn't break than I bet the mechanics that put it back on screwed something up that caused the chain to jump the gear and fall off...
