cruise control shuts off going down the road
Old 10-31-2014, 01:00 AM
chris2691's Avatar
chris2691
chris2691 is offline
Cool cruise control shuts off going down the road
ok last year I bought a 2004 dodge 1500 5.7 hemi and it has a few gremlins that I have to sort out. while going down the road I can turn the cruise control one and it will work for a while or just shut off for no reason the light will just go out and some times it will let me turn it back on but some time it will not. Im not really sure were to start on this one has anyone else experienced this problem. It does not matter if the steering wheel is turn or if the windows are in operation at the time like I have ssen in other threads
Old 10-31-2014, 06:10 AM
chuck_hammer's Avatar
chuck_hammer
chuck_hammer is offline
replace your brake light switch..... mine did the same thing...this spring.
it was easy for me to tell. as I was pulling a trailer at the time....brake lights became intermittent..... brake lights going ON when brake NOT applied ....
switch is 12 dollars... and 5 minutes to changed... and not tools needed.
Old 11-02-2014, 09:35 PM
chris2691's Avatar
chris2691
was on the way to pick up the new switch and realized that the cruise only is working under 50 miles per hour
Old 11-03-2014, 02:03 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Usually has to do with the abs/speed sensor in the bearing hub assembly
The following users liked this post:
Jmn822000 (06-12-2021)
Old 11-03-2014, 06:52 AM
chuck_hammer
agreed. speed sensor inside front wheel bearing assembly.. bearing may be getting ready to fail....
on my 04 Ram v6,, both front wheel bearing went bad at 37,000 miles. same ones used on the v8... 2 and 4 wheel drive...
Old 11-12-2014, 09:46 PM
Jmn822000's Avatar
Jmn822000
Jmn822000 is offline
My drive-by-wire light came on when mine quit working. Could be a possibility. Check connections on the throttle body if that's the case.
Old 06-12-2021, 12:09 PM
Jmn822000's Avatar
Jmn822000
Lol oops
Quick Reply: cruise control shuts off going down the road
