A/C, Heat Temp Control Back light replacement
Old Nov 3, 2014 | 11:32 AM
tvacchino's Avatar
tvacchino
Default A/C, Heat Temp Control Back light replacement
Ok,
Before I rip my dash out. Anyone have direction/ in -sight for removing and replacing the bulbs for the A/C, Heat Temp control cluster area?
I did some poking around and can't find any quick and or logical way to get to these bulbs? Please tell me I don't have to remove the whole dash for this!
Just for "Ha Ha"s" I checked the Manual and it states to "Bring your vehicle to your Dealer" for replacing any dash/ cluster lights. Ya okay.
out,
t
Old Nov 3, 2014 | 05:26 PM
Prismatic's Avatar
Prismatic
Originally Posted by tvacchino
Ok,
out,
t
Those are super easy actually.
Step one is to go to dodge and get the three lights you need, or just order them on amazon ->
here here
Next look at the radio bezel locate the Phillips screw located here.
A/C, Heat Temp Control Back light replacement-rxzbcqz.jpg
Remove the screw. Now, gently pull on the radio bezel in the locations indicated here to free the bezel
A/C, Heat Temp Control Back light replacement-esztitw.jpg
With the bezel free, gently move it away from the dash and disconnect the connections at the back of the HVAC control unit.
A/C, Heat Temp Control Back light replacement-cizyhdd.jpg
Inspect the unit, locate the three bulbs as indicated above. Twist them to remove, insert new bulbs and twist to lock.
Installation is the reverse of removal.
Old Nov 3, 2014 | 05:58 PM
Prismatic's Avatar
Prismatic
And I just saw you have a 2007. Slightly different procedure, same basic thing though.
Old Nov 3, 2014 | 11:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you get LED bulbs (recommended) and you put them in and they don't come on, take the out and rotate them 180* as they are polarity sensitive
Old Nov 4, 2014 | 08:00 AM
tvacchino's Avatar
tvacchino
Thanx Guys!
Pretty straight forward. Even if not very obvious from looking at the dash.
Yes. I was thinking of going the LED route while I was at it.
out,
t
