abs/brake light issue solved
06 1500 SLT 5.7L 4x4
was having an issue with the abs/brake light coming on randomly. no-one could pin point the cause. it ended up being the sensor in the master cylinder reservoir. I guess the low brake fluid float was stuck. gave it a few healthy taps to try and free it. seemed to work. no more abs/brake light. hope this helps people with the same problem.
[QUOTE=devilfish;3206479]06 1500 SLT 5.7L 4x4
elps people with
I'd just about bet you the lights will return. When it happened to my 06 it took a trip to Dodge for a reconfiguration between the ABS sensors and the computer...then they went out for good. My lights came and went for about two years til they finally came on and stayed on, and Dodge is the only place I could find with the software to reset it...95.00 and well worth it
elps people with
