Any assistance would be great to try and fix this
Old Nov 16, 2014 | 01:08 AM
The_hooligan's Avatar
The_hooligan
Default Any assistance would be great to try and fix this
Hello all,
I have a 2006 Dodge ram 1500 5.7L TRX, The other day i was driving on the freeway and my truck lost everything. I mean i lost all the power to my motor and all my electrical, including my power steering my power steering even seemed to feel like it locked up. The truck did not throw any codes, I checked my battery and also my alternator with nothing wrong, knowing no codes were thrown i still attempted with no luck. has anyone else experienced this or have any ideas that would be great.
Note: i did call dodge manufacture and they told me i needed to duplicate the situation even after telling them that it could possibly cause a serious accident.
thanks again
Old Nov 16, 2014 | 01:28 AM
Mlj1111's Avatar
Mlj1111
Are you sure you lost all power?
What I mean is.. when your truck died, did the check engine light come on at the very least?
Power steering is powered by a pump connected to engine, therefore when engine stalled, you lost your steering.
My first guess... IF you have power.. IE radio still works, ect is that perhaps its the crank sensor or could be fuel pump.
I cannot really guess what is going on if you totally lost power though. Grounding issues from engine to chassis would not cause total loss of your electrical system, though it could cause your engine to stall out also. Ground strap that goes from back of both heads and drops down on passenger side at rear of engine. Usually bolted to transmission bell housing. This strap is pretty thin and corrosion and flexing breaks it.
Mike
Old Nov 16, 2014 | 01:32 AM
The_hooligan
everything went dead. no radio,lights and the the heater all the gauges turned off as well.
Old Nov 16, 2014 | 01:36 AM
Mlj1111's Avatar
Mlj1111
Check all the wiring connections from the altenator to the battery and all the grounds. That means also at bottom of block ground wire going up to your battery.
Cant help but ask.. How did you get home?
Mike
Old Nov 16, 2014 | 01:39 AM
The_hooligan
Awesome i will try that next in the morning. thanks for your advice Mike!
Old Nov 16, 2014 | 01:49 AM
Mlj1111's Avatar
Mlj1111
Ah yeah. I have heard of PCMs that for some reason or another got moisture in them, essentially rusting circuits together. That can be cleaned and put back together, but I doubt that's your issue.
I am guessing its a ground wire of some type.
How did you get the truck home?
Mike
Old Nov 16, 2014 | 01:51 AM
The_hooligan
I ended up have to call AAA but i was able to drive the truck today for about 20 min with no issues. mind u i have a empty parking lot at the end of my road that i did circles in lol.
Old Nov 16, 2014 | 01:56 AM
Mlj1111's Avatar
Mlj1111
Yeah.
Ground issue more then likely.
I am going to bed.
I am guessing you'll find something loose and if not post back and someone else maybe can chime in.
Regardless, please post what the fix was.
Thanks
Mike
Old Nov 16, 2014 | 01:58 AM
The_hooligan
Thanks for your help i will update either way.
Old Nov 16, 2014 | 08:38 AM
chuck_hammer's Avatar
chuck_hammer
have battery Load tested.. I have seen batteries have an internal buss crack... full power then completely dead... tap side of battery with rubber hammer and retest...
a battery is 6 batteries connected together.... 6.. 2 volt cells...
otherwise.. a power cable.. or ground cable.. and/or corroded connection for same.
