Rear end or trani help plz
Old Nov 18, 2014 | 10:03 AM
CopenghagenHemi22's Avatar
CopenghagenHemi22
Default Rear end or trani help plz
Okay guys I'm in Illinois and weather is getting cold. When in reverse my rear end whines bad. And it will do it in drive too. But after then running temp increases the whine will taper away. Also, if I hammer it wide open the truck will hit 5500 and not shift. Can anyone offer any insight please. I'm not very familiar with the driveterrain work so any help wouldnt hurt. Thanks in advance.
Old Nov 18, 2014 | 08:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Drive train whines because the backlash is off and the gears are out of "mesh". When was the last time you changed the rear differential oil or transmission oil? How many miles are on it?
Old Nov 18, 2014 | 11:21 PM
CopenghagenHemi22
Very recently I changed both. Both within the past 3 months.
So narrowing it down to the rear end, any ideas where to look and solve problem?
And why does it stop when truck is at operating temps?
Also, is this causing the hesitation when putting it into drive?
And is this why I hear a loud clunk, when putting it into reverse?
Sorry for the bombardment, just wanna try and figure it out if its still saveable.
Old Nov 19, 2014 | 01:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Nothing you can see to determine. With backlash, youre talking 0.001 inch increments. It needs to be measured with dial calipers
It stops when at op temp because it might be slightly off and metal expands as it heats up.
Rear diff and trans are two different issues. One has nothing to do with the other. Your engine transfers power to the trans which turns the drive shaft. If you put it in gear and it doesnt drive, chances are the trans where as its hydraulic/electrical over the read diff which is mechanical
Clunk in reverse has to do with excess play in the rear differential
Again, sounds like you have two issues and each are separate and both can be costly.
Old Nov 19, 2014 | 01:13 PM
CopenghagenHemi22
So would it be that when I'm full throttle and the truck hits 5500 and doesn't shift is part of the trani issue? I'm wondering one of them is affecting the other.
Old Nov 19, 2014 | 01:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
One does not affect the other and stop putting it at 5500 before you tear something else up and end up with more issues.
If you want something to race, there are lots of sports cars and bikes out there. A 6000 lb truck isnt it.
Old Nov 19, 2014 | 01:23 PM
CopenghagenHemi22
No ****, I'm not retarded. But you should be able to have it wide open and it should shift, i.e. merging on interstates.
Old Nov 19, 2014 | 01:57 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes, you should. Which leads to a trans issue.
But your gear whine and driveshaft clunk are rear diff related
This makes it two separate issues
Old Nov 19, 2014 | 03:30 PM
scwpd's Avatar
scwpd
When you changed the diff fluid did you put the friction modifier in if you need it?
Old Nov 19, 2014 | 05:14 PM
Prismatic's Avatar
Prismatic
Three issues, you're forgetting the driver.
