my 03 dodge diesel will not start
Old Nov 24, 2014 | 10:39 PM
gcon4418's Avatar
gcon4418
Default my 03 dodge diesel will not start
I blew a power steering hose , cleaned up the mess replaced the hose, driving down the road, truck revs up to about 3grand and dies the truck will not start. I have replaced the fuel filter, fuel pressure regulator and new batteries still no start , took to dodge dealer cause I had a p2509 my mechanic buddy said computer maybe needed to be flashed , dodge mechanic said computer is good and needed to do a fuel test , lift pump good, injector pump good but I only had 149 psi at rail he checked the fuel pressure relief valve it was bypassing like crazy, he says I needed a new one put new one on fuel pressure at rail is no 500 psi but still no start , now he is testing the injectors.....anyone else been through this any ideas.....
Old Nov 25, 2014 | 01:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any other codes since you cleared the p2509
Old Nov 26, 2014 | 08:53 AM
gcon4418's Avatar
gcon4418
no other codes , can the crank shaft sensor although there are no codes be bad, since it does sit close to where the power steering line blew.
Old Nov 26, 2014 | 09:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
A good way to test that being you have no current codes is to disconnect the connector to it and try to crank it and see if you get codes then.
Old Nov 26, 2014 | 07:26 PM
gcon4418's Avatar
gcon4418
that's a good idea, I will try that .
Old Nov 27, 2014 | 09:38 AM
dcdyllon#FordTechnician's Avatar
New Member
took the words right outta my finger tips haha
