Transmission switch
Old Dec 5, 2014 | 07:45 PM
sgt3470's Avatar
sgt3470
Default Transmission switch
Hello I have 2007 Dodge mega Cab 1500 Hemi.
My check engine light came on when I check the code it reads
TRS trans rely switch Has anyone heard of this switch and were it my be located. Thanks Carl
Old Dec 5, 2014 | 09:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Please post the DTC # that you have
Old Dec 8, 2014 | 10:34 AM
DodgeCares's Avatar
DodgeCares
What was the code? There is a Transmission Range Sensor (TRS).
DESCRIPTION
The Transmission Range Sensor (TRS) has 3 primary functions:
  • Provide a PARK/NEUTRAL start signal to the engine controller and the starter relay.
  • Turn the Back-up lamps on when the transmission is in REVERSE and the engine (ignition) is on.
  • Provide a transmission range signal to the instrument cluster.
The sensor is mounted in the transmission housing near the valve body, just above the pan rail. It's in the same position as the Park/Neutral switch on other transmissions. The TRS contacts a cammed surface on the manual valve lever. The cammed surface translates the rotational motion of the manual lever into the linear motion of the sensor. The cammed surface on the manual lever is comprised of two parts controlling the TRS signal: The insulator portion contacts the switch poppet when the manual lever is not in PARK or NEUTRAL. The manual lever itself contacts the poppet when the lever is in PARK or NEUTRAL; providing a ground for the signal from the starter relay and the appropriate engine controller.
Old Dec 10, 2014 | 05:39 PM
sgt3470's Avatar
sgt3470
Default Thanks
Thanks that is the switch. TRS
