Need Help
Old Dec 8, 2014 | 12:35 AM
gundampilot's Avatar
gundampilot
Default Need Help
I have a 05 ram 1500 with 5.7 hemi. A new motor was put into the truck when i bought it and the rear main seal plus a new oil pan gasket were put in. The truck has a slow oil leak coming from the rear and looks like passenger side rear. Is there anything we missed and anything that could cause this leak?
Old Dec 10, 2014 | 08:46 AM
Izero's Avatar
Izero
You sure that the rear main was put in correctly?
Are you sure the rear main seal was the original issue in the first place?
Old Dec 10, 2014 | 09:42 AM
How long have you had it? Who put the motor in? Why was the motor replaced? How many miles on the new motor? Is it leaking from the top of the engine (valve cover/intake gasket) or the bottom? (oil pan)
Old Dec 12, 2014 | 12:11 PM
gundampilot
took it to dealer today. They said i need a new oil pan and gasket and it would be 830 to do it
Old Dec 12, 2014 | 12:12 PM
gundampilot
Is dorman a good oil pan and does anyone have a diagram of how the bolts should go in?
