Brake Pads
Old Oct 25, 2005 | 07:07 PM
Kevno6's Avatar
Kevno6
Default Brake Pads
Does any one know how to remove brake pads from the rear calipers. For the life of me I can't get them out. I tried for over an hour yesturday. Thank You
Old Oct 25, 2005 | 09:07 PM
PyRoHAvoC's Avatar
PyRoHAvoC
Default RE: Brake Pads
i've got the manual for my truck and it goes into some great detail but mine is an '03
Old Oct 26, 2005 | 03:14 AM
hemiyellow's Avatar
hemiyellow
DC Insider
ORIGINAL: PyRoHAvoC
there should be no difference from an 02 to an 03 on the 1500. i would tell you, but it's been awhile since i replaced em on my old truck, so i cant remember for the life of me right now. i wanna say that once u pull the caliper off, i wanna say that the pads slide out but i cant remember for sure.
Old Oct 26, 2005 | 12:34 PM
osteodoc08's Avatar
osteodoc08
Go here and download a service manual for your truck. It will answer any and all questions you have about your brakes.
Old Oct 26, 2005 | 12:36 PM
tommiwan's Avatar
tommiwan
Once you pull the calliper off the breakpads do slide out. I did mine a few months ago.
Old Oct 26, 2005 | 04:47 PM
bbunn29's Avatar
bbunn29
Once you pull the caliper off, there are the metal clips that hold them in, pull back the clips and slide the brake pads off. I just did brakes all of the way around on my 02 quad cab. Hope this helps.
Old Oct 27, 2005 | 02:05 AM
Kevno6's Avatar
Kevno6
I am an idiot, I have never done truck brakes before and on my Thunderbird I have only a caliper. I took off the caliper adapter with it. I was not sure if I should have loosen those little bolts on the back because they have little rubber boots on them and did know they were for the caliper themselves. Thanks hosteodoc08 for the link to the manual it is much appreciated. Thank You everyone
Old Oct 29, 2005 | 03:19 PM
osteodoc08's Avatar
osteodoc08
No problem
