2002 4.7, wrong radiator?
Old Dec 11, 2014 | 09:55 PM
Garef's Avatar
Garef
Default 2002 4.7, wrong radiator?
I got a new radiator which has an overflow outlet to the right with a pipe running to the reservoir which was the same setup as my old one. However on my new one there is a small opening which looks like another overflow outlet below the fill up valve. What happens is whenever I turn on the engine, coolant pours out of the second outlet and thus I cannot keep the cooling system filled.
Did I get the wrong radiator or am I missing another pipe that will keep the coolant circulating.
I can take pictures if needed to make more sense.
Old Dec 11, 2014 | 10:47 PM
If your old radiator had nothing connected to that port then that's the wrong radiator. Maybe plug it?
Old Dec 12, 2014 | 08:01 AM
rtmtrrdr's Avatar
rtmtrrdr
I bought a new one and it had the same extra plug.I just plugged it and it has been like that for 3 years now with no problem
Old Dec 12, 2014 | 08:38 AM
Garef's Avatar
Garef
What did you plug it with?
Just don't want it blowing out.
Old Dec 12, 2014 | 08:55 AM
Find a brass or other material plug with threads of the same size. Use Teflon tape to seal the threads.
Old Dec 12, 2014 | 09:35 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Home Depot, plumbing section.
Old Dec 12, 2014 | 10:16 PM
rtmtrrdr's Avatar
rtmtrrdr
It had an extra nipple on it like a hose would.I took a piece of hose,stuck a bolt through it and hose clamped it on the radiator and where the bolt went in the hose.Didn't look to good but it worked
