Heat Issues, please help
The heat on the passenger side of my truck is coming out nice and hot but the heat on my driver side is cold. Has anyone else had this issue? Any help would greatly be appreciated.
Ken
Ken
Common problem. Do a search for blend door failures
It's a ridiculously common problem. I'd wager the percentage of trucks that will experience the problem approaches 100% the more time passes.
Ive had the problem, what i did was disconnect the 2 heater hoses from the heater core at the firewall and back flushed the heater core with a water hose a couple times, then i used compressed air to get as much of the tap water out of the core that i used to backflushed and i had heat on both sides again. Some people swap the heater hoses around and let it flow backwards through the heater core due to partially clogging up heater core.
