Rough engine rpm under 2000 RPM
I need some help. I am a newbie here. First I own a 2007 Dodge Ram 1500 SLT 4x4 with a 5.9 hemi. On the way home tonight I started to get a bad vibration when my RPMs were under 2000. I shifted the tranny out of overdrive to get high RPM range But still the roughness is still there. At a stop Idle is very bad but does not stall. What could be the problem? I need to know where to start.
got a check engine light this morning for cylinder #1 misfire. Changed coil and plugs in that cylinder to see if improved. It still is rough rpms but not as bad. can run in overdrive. I have not been able to take care of normal services such as tranny and other things but have changed engine oil regularly. Just getting back on feet so I can take care of those things......will do rest of plugs this weekend.
