Light problem
Old Jan 25, 2015 | 03:31 PM
troystoy63's Avatar
troystoy63
Default Light problem
I have a 2002 Ram 1500 and live in WI
My parking lights and tail lights quit working. After research found probable cause in fuse box. Disassembled and attempted to repair. After I put back together I still had no parking or tail lights, plus now no headlights or brake lights or turn signals. I purchased a used fuse box from Georgia. Cleaned and installed on truck. No lights at all with light switch. When I turn the key to on position the headlights parking lights and tail lights come on. No brake, turn or high beams, also fog lights don't work, wipers also not working now. What should I check next?
Old Jan 25, 2015 | 06:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe you have a bad used part or maybe it looks the same but has a slightly different part number making it slightly different
Old Jan 29, 2015 | 12:19 AM
troystoy63's Avatar
troystoy63
Default PN
The fuse box is the same part number, looks exactly the same
Old Jan 29, 2015 | 12:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Same part number and same piece but not working either means you damaged something or it was already damaged
