3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Is it true that taking cat of give better perform and mpg and if you run straight pipe what do you do about the o2 sensor so lights won't come on and then does it need tuned up after that
The cats on your truck are high flow cats. What that means is, if you take them off. You aren't going to see any gains. Not to mention you need a tuner.
