Small Evap Leak
I cleaned the MAF, and the throttle body in my truck. Put it back together double checked it engine light came on. Pulled the negative battery terminal for 10 minutes, put back together it was fine for 20 miles. Light back on again. Had auto zone run it they say it is a P0442 Evap small leak, and a p1684 batter power disconnected. In the past I Had it smoked and a mechanic replaced a vent connector, leak detection pump, and purge solenoid.
I feel like every time I go to a "mechanic" they are just part swapers. Is there a common issue that anyone is else is having with evap leak? I can't seem to figure it out and I can't pass emissions until I do.
Thanks
Thanks
Look under the truck and in the engine bay for any plastic hoses, most of them are for the evap system, look at the rubber ends for cracks, you can also smell around the fuel cap to see if it's leaking. There should be no fuel smell.
