Please Help!
Old Feb 10, 2015 | 09:17 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Please Help!
I want to add the following to my truck (2006) I need parts and numbers please: So everyone is aware I have the 06 dash and center console (console isn't in yet).
Dual Climate Control
Power Rear Window (Factory switch)
Heated and Cooled Seats (Factory Switches or a cool looking aftermarket)
Add USB and 110v to center console (have an 06 floor console in the truck have to be the top because a vault is going in the bottom)
110v to dash
110v, USB, Rear heated seats, and regular power outlet to back of console)
UConnect (06 one will work my buddy did the same thing)
Also just bought the console so I would like the rear vents to blow air
Any ideas and tips will help. I also need some ideas on where to put some accessory switches. I would like some cool switches for train horn, led light bar, led bar used as back up lights, led bars around the truck, and rock lights. I have worked on Rams (all I owned) so Im not some guy who doesn't know about trucks lol. Just kind of lost and cant find the rights parts so I would like the numbers. I heard of adding another fuse box? These will be running off of my second battery.
Old Feb 11, 2015 | 10:39 AM
HemiLonestar's Avatar
HemiLonestar
110v to dash
1. If you did not have dual climate before you will need to install the split doors in the hvac box, can't just plug in the control for it and expect it to work (in case you didn't know)
2. Cubby hole under the stereo is where the switch panel goes for window and heated seats...
3. Heated front seats were an option but not cooled. That's gonna be custom.
Here's the 06 parts book, have at it:
http://www.mediafire.com/view/n0g1r8...rts_Manual.pdf
Old Feb 11, 2015 | 12:04 PM
chuck_hammer's Avatar
chuck_hammer
a few wrecking yards... for parts... Good Luck.
Old Feb 12, 2015 | 06:58 AM
MoparFanatic21
Thanks yes I knew about the coinage control wasn't plug and play. I posted it for the part number. The cooled seats I knew would be custom, just thought I'd post it case anyone had a cool idea. Thanks for the info
Old Feb 12, 2015 | 09:35 AM
HemiLonestar
If you want heated and cooled seats, I'd suggest finding a set from a vehicle that has it built into the seat and wiring it in. I know the newer Chargers it's an option as part of the overall climate control.
Old Feb 12, 2015 | 09:00 PM
MoparFanatic21
I had that planned but didn't know if factory switches would work
Old Mar 20, 2015 | 06:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sorry I'm late on this. Did you get all of the info you needed?
Old Mar 28, 2015 | 03:13 PM
MoparFanatic21
No I need all the part numbers. I dont have the power rear window and doing research I think there is a motor I need to. Any help is appreciated.
Old Mar 30, 2015 | 12:37 PM
HemiLonestar
Did you use the link I gave you for the factory parts book?
