Recall For My '05 Ram 9.25" Pinion Nut
Old Feb 13, 2015 | 02:07 PM
Daves69's Avatar
Daves69
Default Recall For My '05 Ram 9.25" Pinion Nut
Don't know if it's posted yet. Got mine today. Say's............
"The rear axle pinion nut on your truck may have been built without an adhesive patch on the pinion nut threads. The lack of this adhesive patch could allow the rear axle pinion nut to loosen and/or the rear drive shaft to separate from the rear axle. A loose pinion nut could cause the rear axle to seize and a separated drive shaft could cause a loss of motive power. Either situation could cause a crash without warning."
A little different from what the link says...........
P77 / NHTSA 14V-796
http://www-odi.nhtsa.dot.gov/cars/pr...h&summary=true
Old Feb 16, 2015 | 01:39 PM
adeathman's Avatar
adeathman
I got mine in the mail the other day. Says no parts are available right now, and to wait for another notice when they become available.
Old Feb 16, 2015 | 09:40 PM
joshv75704's Avatar
joshv75704
I had this happen to my 05 ram back Oct of 14. Had to completely replace the whole rear end out of pocket. Almost $4000. I actually filed a complaint with the NHTSA. After reading about this happening to other Ram owners. Haven't received anything in the mail yet. But my question is if they have issued a recall. Will I get get my money back? Any info would be great. Thank you.
Old Feb 18, 2015 | 11:04 AM
Daves69's Avatar
Daves69
josh, I wouldn't hold my breath on a refund but you can give it a shot. I was able to get a replacement spare tire for my '02 Durango as a metallurgist friend verified the cable was faulty after discussing with a area rep. Never know unless you try.
Get your ducks in a row. Diagnosis, repair estimates, receipts, etc. Document everything. Politely discuss with a positive attitude the issue with the service manager on cause and effect and work this recall notification (whether you get one or not) into the discussion. Escalate as needed up to Chrysler area rep. Maybe you'll get something out of it.
What I find a bit disturbing is the recall references an"adhesive patch" on the nut. Then the recall link (P77 / NHTSA 14V-796) refers to an undersize spline condition.
If it is a "mechanical" locknut no adhesive should be necessary by the way. Manufactures tend to put their logo on locknuts so I'll need to look at mine and see what it has before taking it in.
