Hemi losing power
All,
I have an '03 Hemi Ram 2500.
Truck is having an issue with losing power and MPG has decreased to 9 MPG. Dealer cannot ID the problem.
Tuck has 60,000 miles approximately.
So far, the following has been done:
- Plugs have been changed and service is up to date
- Transmission has been checked and is functioning normally
- pressure test on the fuel system checked ok.
- no codes on the computer
- exhaust has been pulled off and back pressure appears normal.
Problem is persistent mainly when towing. I don't notice the issue with everyday driving except the sharp drop in MPG.
Thanks.
Thanks.
A broken valve spring is dreadfully apparent and wouldn't just present its self as a loss of MPG, considering OP states that the only apparent symptom.
Edit - As others in your previous thread suggested marnold, did you replace the O2 sensors? Forum members and the "certified tech" both suggested it.
Trending Topics
For sure. A broken valve spring won't idle and will run too rough to drive.
