Compression Test Results, Advice please
Old Feb 18, 2015 | 02:22 PM
Garef's Avatar
Garef
Default Compression Test Results, Advice please
2002 Ram, 4.7L
184,000 Miles
Cylinder #
1- 115
2- 135
3-130
4- 130
5- 120
6- 125
7- 115
8- 130
The test was conducted dry and with wide open throttle
Wet test of Cylinders 1 and 2 only
1- 135
2 - 142 (roughly)
Any input on these numbers would be appreciated.
Thanks
Old Feb 18, 2015 | 03:59 PM
Prismatic's Avatar
Prismatic
Generally you'd want to see each cylinder wearing at about the same rate, keeping within about 15%
Cylinders 1 and 7 are a tad low compared to the rest of the engine. Any lower on those two and you may start to notice a misfire.
Old Feb 18, 2015 | 08:51 PM
Garef's Avatar
Garef
I changed the plugs a few weeks ago when I was having a major misfire with fault codes. I have still been having a slight misfire but it comes and goes and from what I can tell only comes under heavy acceleration.
I also had an overheating problem recently.
Just trying to see if I am heading for the worst case scenario.
Old Feb 18, 2015 | 11:07 PM
Prismatic's Avatar
Prismatic
Well, you're certainly heading for a scenario, but not necessarily worst case. You may have popped the head gasket when it overheated. Do a search on this forum for 4.7 overheat and you'll find a lot of resources. They don't take kindly to overheating.
