problem with power steering
Old Oct 28, 2005 | 02:13 AM
PyRoHAvoC's Avatar
PyRoHAvoC
Default problem with power steering
my mechanic is doing some research and is gonna call me back but here's the problem
first off to my knowledge, the fluid is at its proper level but i will check again in a bit
here's the deal:
everytime it rains and i drive at a decent speed through a nice sized puddle i loose power steering for anywhere from 10-40 seconds ... belt is in good condition and no aparent leaks anywhere ...
mechanic thinks the belt is getting wet and slipping over the pulley ... says chrysler minivans had a similar problem but the belt would slip off in the process and the problem was solved with some sort of shield
is it possible that when i hit a big puddle the pump empties the resevoir and i don't get my power steering back until some returns to the pump? or is it more likely that the mechanics theory is correct?
any and all input will be appreciated. thanks
Old Oct 28, 2005 | 03:05 AM
2004 Hemi Quad's Avatar
2004 Hemi Quad
Default RE: problem with power steering
Chances are the belt got wet and slipped over the pulley. If it only happens when it gets wet. My wifes Neon does the same thing only the the alternator.
Old Oct 29, 2005 | 12:17 AM
PyRoHAvoC's Avatar
PyRoHAvoC
ORIGINAL: 2004 Hemi Quad
if that's the case then how do i fix it because it does it guranteed everytime ... i can't have a truck that can't drive through puddles ... that's just stupid ...
Old Oct 29, 2005 | 03:28 PM
osteodoc08's Avatar
osteodoc08
Make sure the belt tensioner is keeping the belt nice an tight. You can also take the belt off ans spray the belt dressing on it, but be careful, it can go everywhere ans stains/paints almost permanently.
