P0300
Old Feb 25, 2015 | 02:11 PM
Gorhad's Avatar
Gorhad
Default P0300
Hi all
Can anyone tell me what are the most common causes of a P0300. My truck threw the code today this morning, so i cleared it and it threw it again later this afternoon. The thing is i didnt feel anything different with it at all. No shudder no sluggishness nothing
Thanks
Old Feb 25, 2015 | 02:13 PM
Google:
A code P0300 (random misfire) may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked/leaking EGR valve / passages
  • Faulty camshaft position sensor
  • Defective computer
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
SmokinJoe02's Avatar
SmokinJoe02
P0300 Multiple Cylinder Misfire
Tuneup time?
SJ03
Old Feb 25, 2015 | 02:14 PM
SmokinJoe02
Jinx! Lol
sj03
Old Feb 25, 2015 | 02:15 PM
Originally Posted by SmokinJoe02
Jinx! Lol
sj03
Ha! Yes, I'd start with a general tune up.
Old Feb 25, 2015 | 02:32 PM
Gorhad's Avatar
Gorhad
Recent tuneup was done back in November while stripping down the right dylinder head that had dropped a valve seat. I replaced all plugs and coil packs, cleaned the MAF and throttle body. Im jut paranoid that this may relate to the problem eccountered in November.
Basically
Stuck thermostat lead to over heat which in turn split radiator and then while trying to get home, some 3 miles away at that time it dropped seal in #2 cylinder causing valve to lodge open, rocker arm dropped off and then must have lodged against lifter valve housing and consequently smashed the housing
At that stage i had not just a P0300 it said it was a multiple cylinder misfire.
But this just says random
Old Feb 26, 2015 | 10:22 AM
Gorhad's Avatar
Gorhad
So it's done it again today only this time the check engine light came on and within 30 seconds went off. Code was still stored and was again
P0300
Old Feb 26, 2015 | 10:26 AM
So have you checked anything mentioned above?
Old Feb 26, 2015 | 10:59 AM
Gorhad's Avatar
Gorhad
Plugs and coils are new. Not sure how to check the egr and cps.
Thanks
Old Feb 26, 2015 | 11:05 AM
Gorhad's Avatar
Gorhad
So perhaps I should go buy a maf sensor cps and egr to eliminate those?
