This ever happen to you? Transmission Quirk
Old Nov 4, 2005 | 11:24 AM
Quacker's Avatar
Quacker
Default RE: This ever happen to you? Transmission Quirk
Well it happened to me also, I was thinking it was just me.
Old Nov 4, 2005 | 12:51 PM
05_black_beast's Avatar
05_black_beast
ORIGINAL: DonG
I've heard of several with similar problems that ended up being the range selecter in the trans.
Sounds about right. May not be sending a signal to trigger the solenoids.
Old Dec 15, 2005 | 05:20 PM
DodgeFam's Avatar
DodgeFam
This problem happens to me on a daily basis. itook it to the dealership to get it fixed but it still does it. One time it even stalled on me while i was reversing(and i have an automatic)
Old Dec 15, 2005 | 05:42 PM
Limedust's Avatar
Limedust
I've done this on about 3 different occasions, but each time I went back to check the gear selector, I found that I didn't have the shifter fully seated in the Drive "notch". Next time it happens, try wiggling the shift stick and see if it pops into position.
Old Dec 15, 2005 | 05:58 PM
BigE's Avatar
BigE
Another item to look into is the PRNDL assembly. Even some of the electric ones with the 'box' that appears around each letter have a cable that attaches to the gear selector lever. I think over time the cable and plastic housing can strech and could be off just enough to indicate you are in a gear, but the transmission shift lever is not quite in gear. It may be possible to adjust the PRNDL indicator (by adjusting the attached cable) to better match your transmission gear shift selector.
