Power steering problems and questions
Old Mar 15, 2015 | 06:06 PM
Greyhound101's Avatar
Greyhound101
Default Power steering problems and questions
Hi, newbie here. In my '04 5.7, I've had a power steering fluid leak for quite some time now. The truck only has 83K miles so obviously I don't drive it often. Before I do, usually I will fill the reservoir up from where it leaked out. At this point, I don't know exactly where it is leaking. Yesterday, I filled it back up but when I drove it, there was a sort of whine and small vibration when I turned the steering wheel left. It was more noticeable at high speeds. When turning right, I didn't notice a problem. My question is, does this seem like power steering or rack/pinion problems? Also, in trying to search this problem, I did notice where I was supposed to use ATF4 tranny fluid rather than the standard power steering fluid that I've been using for years. Don't know if this caused the problem or if I accidently drove it with the reservoir too low. Please help diagnose this problem. Thanks.
Old Mar 15, 2015 | 06:10 PM
chuck_hammer's Avatar
chuck_hammer
the power steering COOLER is known to leak (rust)
the low pressure side of the hose.. the clamp is known to break.. cause leaks..
I had both issues. ... around 45,000 miles. on my 2004....
Old Mar 17, 2015 | 07:03 PM
Largefarva's Avatar
Largefarva
^Both of those, yes. If you've been driving it for this long with a leak, why not have it looked at so you know what you need? Yes, you may have done some damage using p/s fluid instead of atf4, probably not, but maybe.
