Fan and Water Pump Removal tool
Old Mar 17, 2015 | 01:38 AM
alex_m712's Avatar
alex_m712
Default Fan and Water Pump Removal tool
Saw some of the ridiculous prices on the spanner to remove the fan shaft from the water pump pulley. Here's a cheap alternative.
-Get a piece of 1" steel square tubing
-Drill 2 5/16" holes, 4"(I think) apart on the end
-Install 2 5/16" nuts about 2" long with washers
Should cost under 15 bucks from a hardware store and gives a ton of leverage.
Old Mar 17, 2015 | 06:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can do it even more simple than that. Take a screwdriver and go through the pulley and against the water pump and hold it while you have a pipewrench on the fans clutch and whack it with a dead blow hammer. Works every time.
Of course you can "rent" the tools from any autoparts store and take them back when you're done which in the end costs nothing at all.
Old Mar 17, 2015 | 08:58 AM
chuck_hammer's Avatar
chuck_hammer
to hold the pulley.. I use a craftsman rubber strap wrench.. and a loner wrench from Advance Auto Parts...
multiple solutions for problems.
Old Mar 17, 2015 | 01:36 PM
alex_m712's Avatar
alex_m712
Yeah dont worry tried those kind of solutions, this thing was TIGHT, so this a cheap solution that will give you alot of leverage.
Old Mar 17, 2015 | 03:28 PM
chuck_hammer
if I run into one .. I will give yours a try.. cheap and easy... Thanks for sharing
bookmarked...
Old Mar 17, 2015 | 08:43 PM
Largefarva's Avatar
Largefarva
With the belt on and air hammer with pointed bit works great.
But good thinking with that too.
