Fed up with this transmmission!
I have a 07 Dodge Ram with the Hemi. A few months ago the selenoid pack in the tranny went out. Took it to a tranny shop and they replaced it. No issues. Then we got a bunch of snow and trying to get up an icy hill my 3rd gear blew out. Pulled the tranny and took it to the shop and they replaced the gear and clutch. When taking out the transmission a wire wasnt seen and got snapped. When the transmission was put back in the wire was sautered back together along with the exhaust which was cut off to get the tranny out. Since having this done, i'm pulling several codes. The truck will randomly die when in drive and creeping to a stop or just stopping and I get a check gauges warning light. I'm getting a P0420 Catalyst Efficiency Below Normal (Bank 1), C2101 Battery Voltage High. The check engine light will turn on for a few days then then turn back on for a few days. Now i'm throwing another code P0944 Hydraulic Pressure Unit Loss of Pressure.
My assumption is there could be a few pin holes where the exhaust was welded back on. I assume the wire being sautered back together could be throwing the voltage code? Would either of these cause the engine to randomly die the way it is? I'm at a loss on the last code.... The truck itself seems to be running fine other than the occasional dying. Sometimes while driving i'll notice it seems a bit off like a bit of a lag. Any ideas? I swear if this transmission needs another part replaced i'm gonna lose it!
I think when the transmission was put back in something got screwed up. Immediately after putting it back in the above issues started. The shop didn't put it back in they just did the tranny fix and we put it back in. So trying to figure out what went wrong.
The wire was shortened slightly and I believe that can cause an issue....?
