03 Ram 2500 Hemi Electric Throttle Control
Old Mar 28, 2015 | 11:37 AM
Ben27's Avatar
Ben27
Default 03 Ram 2500 Hemi Electric Throttle Control
Occasionally I get a problem with my 03 ram 2500 hemi. The ETC light (electric throttle control) comes on and blinks repeatedly. This usually happens when I do not let the engine warm up properly. During driving this also happens, it turns on and blinks repeatedly, and when I go to press the gas the truck bogs (moves forward and back), and drives really slow. Meanwhile my RPM gauge flutters like crazy between 2500-4000 RPM. Or it will randomly shut off in me on a stop light. The truck shows a code of P2106 which is a ETC malfunction. My question is: is there a way that I can clean and electronic throttle body, or does it have to replaced?
Old Mar 28, 2015 | 07:51 PM
p38251's Avatar
p38251
You can try cleaning with de chlorinated brake cleaner.
Old Mar 29, 2015 | 02:43 PM
MikeHTally's Avatar
MikeHTally
The brake cleaner could help. The Hemi likes regular throttle body cleanings. Make sure you remove the TB. Otherwise, you won't get a lot of the crude out. Removal is easy. I clean mine 'bout every 10K. You might as well clean/replace the PCV valve while you're at it.
