Starting problems now!!!
So in addition to my other issues I now have a starting problem. Sometimes it starts sometimes it doesn't. Had the system tested at autozone and battery alternator and starter passed. When I push the clutch and and attempt to crank, I just get a loud clunk. If anyone knows how to post a video I will so you can hear for yourself. Terminals are tight and clean.
I would bet its the starter, sounds like the bendix drive is kicking out but the starter not turning. The bendix drive kicking out might be the clunk noise you hear.
Problem could be you have a dead spot on the starter armature. Try tapping the starter with a hammer and see if it starts when it happens again.
Good Luck
Good Luck
