2003 dodge 3500
Old May 25, 2015 | 11:39 PM
TL4716's Avatar
TL4716
Default 2003 dodge 3500
Looking for help with my 2003 doge 3500 5.7 hemi with 6/7 rod knocking
I've come across a 6.1 hemi engine and have been told it will fit in the truck is that true and what is needed to make that happen ?
Old May 26, 2015 | 08:44 AM
Moving to the correct section.
Old May 26, 2015 | 02:03 PM
HemiLonestar's Avatar
HemiLonestar
It will physically bolt in, but that's where the easy part ends. You (like me) have the worst year for hemi custom tuning. Your stock exhaust manifolds will be port mismatched with the 6.1 heads (unless it's just a short block and you're using your stock 5.7 heads). LX shorty header manifolds don't fit in the truck chassis. The 5.7 intake manifold wil be port mismatched with the 6.1 intake ports (unless, like mentioned before, using stock heads). If you tru to use an eagle or 6.1 intake you'll have to convert the accessory drive and swap in an electric fan for the front mount throttle body. Then there is the aforementioned tuning issue. You can probably get it to run ok on a Superchips tune but you'd be leaving alot on the table.
Old May 26, 2015 | 08:49 PM
TL4716's Avatar
TL4716
Okay I hear what your sayin I'm not really looking to invest while lot of money on something that kinda like a gamble was only interested because a few people said it would be easy and that the 6.1 hemi is an upgrade to the 5.7 hemi but not looking for a project either was just wanting to know if it was an easy swap
Old May 28, 2015 | 11:11 AM
HemiLonestar
If you take the 6.1 short block and put your 5.7 heads on (Indy actually sells a budget crate engine like this) then you will have an easy direct swap. If you keep the 6.1 heads on it you've more work ahead of you.
