Tow wiring
Old Jun 8, 2015 | 12:49 PM
patrapper's Avatar
patrapper
Default Tow wiring
2006 1500
None of the lights work on whatever I am towing. Fuses are good.
Has anyone tried to fix this problem? Where should i start looking? Or in your experience should I just rewire the whole thing?
Old Jun 8, 2015 | 02:07 PM
Have they ever worked? Time to get a meter out and start checking voltages.
Old Jun 9, 2015 | 08:59 AM
chuck_hammer's Avatar
chuck_hammer
my 04.. turned out to be the computerized fuse box.. do a search here.. common.. loosing trailer power and lights...
I just installed a powered converter... 45 instead of 500 plus labor.
but Test yours out first.... TEST LIGHT.. and 20 minutes.
Old Jun 10, 2015 | 08:53 PM
dirtydog's Avatar
dirtydog
Moderate User
2006+ is electronically controlled by the TIPM. Very different from previous years.
2006 had a problem with the towing wiring. Well, not the wiring per say but the electronic amperage setting. Higher but typical loads would trip the circuit and the tipm would lock out and disable the towing BUT if I remember correctly, it had something to do with the trucks directionals and hazards as well.
There is a fuse for the tow in the tipm. I dont remember where or what for. Start there.
Bad grounds cause all kinds of failures. That would be the next place to check.
If the truck is factory tow package then the tipm fault TSB would be the next place to visit...dealer as they can and should flash for no charge.
Old Aug 3, 2015 | 11:24 AM
patrapper's Avatar
patrapper
Update,
I'm half decent with my multi-meter, but couldn't find the problem. Been to two private garages who couldn't fix it. The front driver side headlight is out and the one shop said it all was related.
Headed to the dealer now with dirtydog's info
thank you
