Will a rear end from a 2005 fit my 07?
Old Jul 12, 2015 | 11:41 AM
Bigjohnstud's Avatar
Bigjohnstud
Default Will a rear end from a 2005 fit my 07?
My 2007 rear has went out. I've been trying for weeks to find a rear end and finally found one but it's out of a 2005. My question before I buy it is will it fit? I've heard yes and no.
Old Jul 12, 2015 | 02:39 PM
TrueDogman's Avatar
TrueDogman
I believe they will interchange. A little bit different than your situation but I use an 05 in my 03. There is a slight difference between 4wd and 2wd. 2wd does not have the bump stop welded to the axle tube
Old Jul 13, 2015 | 12:29 PM
HemiLonestar's Avatar
HemiLonestar
Should bolt right in, if your 2wd done deal. If you're 4wd the gear ratios have to match.
