Help me ID my engine
Old Aug 10, 2015 | 08:24 PM
volsfan4life252's Avatar
volsfan4life252
Default Help me ID my engine
Ok guys....I recently got a 2002 Dodge Ram 1500 4x4 with 230,000 miles.......at least that's what the title says. As I've been doing routine maintenance this week on it, none of the engine parts are right. For example, my engine clearly has a distributer but the parts stores show that a 2002 has coil on plugs. PCV valve was also different that what the parts store said. I'm thinking at some point, this truck has had an engine swap but how can I be sure? Is there a manufactures stamp or serial number somewhere on the block so I can ID the engine for parts purposes? Thanks in advance for your help.
Old Aug 11, 2015 | 10:28 AM
HemiLonestar's Avatar
HemiLonestar
Sounds like you have a 360 (5.9 gas). A picture would make this alot easier...
Old Aug 11, 2015 | 12:03 PM
volsfan4life252
Old Aug 11, 2015 | 12:23 PM
HammerZ71's Avatar
HammerZ71
5.9 Magnum V8, entirely possible is original engine. Get a build sheet and you'll know exactly how it left the factory...
Old Aug 11, 2015 | 05:50 PM
volsfan4life252
Gotcha. How can tell the year? How do I get a factory build sheet?
Old Aug 11, 2015 | 06:16 PM
HammerZ71's Avatar
HammerZ71
Oh, I'm pretty sure it's an '02. It can only be '02 or very early '03 with a 3rd Gen body and a 5.9 gasser. The 16 year old kid making $7.50 an hour at your parts store just assumed it had a 4.7. An '02 1500 was available with 3.7 V6, 4.7 V8 and 5.9 V8.
Used to be you could get one off the Ram website, haven't tried to in a while. Dealer can print one or send a PM to DodgeCares on this forum with your VIN...
Old Aug 12, 2015 | 09:39 AM
HemiLonestar
http://www-5.dodge.com/webselfservice/dodge/index.html
Click on 'equipment listing' off to the left, then enter your VIN. You'll get an instant .pdf
Old Aug 14, 2015 | 05:21 AM
shanes76's Avatar
shanes76
Thanks hemi, need to see what gears are in mine
