Rear end clunking.
Hello, I have a 2004 ram 4X4 3.92 gears. Yesterday i heard a loud banging, clunking coming from the rear end. I check it out and found oil in the wheel well and leaking from the back of the brake rotor. I'm guessing a bad axle shaft seal. I was worried though cause i don't know what would cause the loud sound. The gears look good and I dont see any silver metal spots (that would cause me to think something was outta alignment). There is some metal in the oil but not big pieces and not much. Could a bearing failure cause this? Look at where the bearing sits around the axle shaft. There are tiny cuts, could this be something?
THX
THX
Lack of oil got the bearing hot. The bearing failed. You will need to do the other side as well. Use some emery cloth to fix the bearing surface. It doesn't have to be perfect. Just no ridges.
that rear end is gonna need a full solvent washing to get any metal out, its pretty clean an not sludgy looking so you maybe fine at the pumpkin but id use new bearings an axles. Since you're in that deep might as well do the pinion bearing if you plan on keeping it. I bet it would take 20ft of emery paper to smooth out those pits in the axle
