Blend door repair
Old Oct 4, 2015 | 08:49 PM
Swick's Avatar
Swick
Default Blend door repair
Hi guys. Currently I've got my dash all taken apart to install a new double din stereo unit and while its all apart I want to get my blend door working again on my ac. Both actuators work; the hot/cold and the inside/ outside blend doors. What's going on is the little white plastic piece that the blend door actuator moves is just spinning and spinning and not moving the door. The door itself is there and moves freely, I can press it closed by hand and it does it's thing. Should it be permanently attached to the white piece or are they two separate pieces? I seen a couple of videos on youtube but nothing conclusive. Having it all apart already it does not look overly complicated to tackle. Any thoughts?
Old Oct 5, 2015 | 08:27 AM
abarmby's Avatar
abarmby
On the white (i believe) paltic end piece of the door, there should be a small plastic peg that the acutator uses to close the blend and other doors in our HVAC systems.
These small pegs over time, weaken and snap off. Also the ends of the doors where the white fittings push in, also become worn and damaged.
Result.... a door that just hangs or flaps about without control.
So to answer your question, yes they are two pieces. The blend door and the white fitting. But both items can and probably are damaged, causing the actuator to just spin as it cannot close the door.
You can get upgraded doors from Heater Treater and replace the doors seperately as I did, or buy stock MOPAR ones and run the risk of this happening again in the future.
Al.
Old Oct 5, 2015 | 10:18 AM
TejasMtnBiker's Avatar
TejasMtnBiker
when I r&r all my doors the new ones had a metal tab so no more worries of plastic snapping when the door servo over extends a tad. I got mine from autozone but look at the part an make sure to not get plastic ones again if anything
Old Oct 6, 2015 | 05:09 PM
mdone's Avatar
mdone
Do the heater treater and just do all the doors. About 6 months after my blend door broke and I propped it halfway with a hanger just to get by, my recirc door broke. This would be a problem once winter hits so I gave in and replaced all 4 doors. Its a PITA but worth it.
Old Oct 7, 2015 | 10:13 AM
HemiLonestar's Avatar
HemiLonestar
Do you actually have the dash apart or just the center bezel removed?
Old Oct 8, 2015 | 08:12 AM
Swick's Avatar
Swick
I have the dash apart all the way to the airbag. That's how I looked at the actuators and described the blend door components.
Old Oct 12, 2015 | 02:18 PM
Swick's Avatar
Swick
Ok, I just had a chance to pull out the blend door. Only took a second actually, wish I did it sooner. I am not sure how to get the little white plastic piece out that moves the door however. I'm sure there's a way to do this without breaking anything. Anyone?
Old Oct 12, 2015 | 06:00 PM
Prismatic's Avatar
Prismatic
There is a way. Have the AC system recovered and then pull the whole HVAC box. Some clips and screws are removed allowing the box to open in two. You'll have 100% unrestricted access to properly R&R any broken components.
Or you can cut holes in the box and fix it with black duct tape, whatevs.
Old Oct 14, 2015 | 10:33 PM
Daves69's Avatar
Daves69
I believe the coupler has 3 tabs that expand out after pushed through the hole to hold it in the housing. There have been several posts on these a search should turn up.
A link to similar fixes in Durango rear air doors may give you an idea for yours. My fix was in post #19..........
https://dodgeforum.com/forum/1st-gen...orks-fine.html
