Gutless in drive, normal power in reverse
Old Oct 20, 2015 | 04:37 PM
Whitefoot's Avatar
Whitefoot
Default Gutless in drive, normal power in reverse
Recently my truck has become very gutless in drive. Going up hills (even smaller hills at low speeds) is ridiculous. Going from a stop light is embarrassing as well. I can floor it and it will just barely roll away. Once i get up to speed it does just fine. Responds well when i give it gas. However, in reverse it is normal, no struggle to start out. Any help on what it is? Recently I've been turning the OD off and it performs better, but still not normal.
2002 Dodge Ram 1500 slt 4wd 5.9. 130k
I'm hoping it's not a transmission problem, I'm a broke college student spending all my money on tuition.
Old Oct 20, 2015 | 09:38 PM
p38251's Avatar
p38251
What's the fluid look and smell like. Could try a pan drop and filter change. May or may not help. If the fluid is dark and smells burnt. Time for a transmission.
Old Oct 20, 2015 | 10:17 PM
Does the 02 still suffer from blown plenums?
Old Oct 21, 2015 | 04:58 PM
Whitefoot's Avatar
Whitefoot
Forgot to mention:
Dropped the pan and changed the fluid about a month ago and it seemed normal. No bad smell and it looked great.
Also it doesn't constantly do it. Usually get a break from it for a day or two a week.
I've had the check engine light on fire awhile now because of an evap leak. Today I pulled the codes to see if something else was in there and I was shocked. Is this relatable to my problem? Googling it it says that it can cause what I'm seeing. How can I fix it?
P208
0203
0113
0300
0201
0202
I think that was all that was in there. Might have missed one
Old Oct 22, 2015 | 08:04 AM
Go here, put in those codes and start troubleshooting.
http://www.obd-codes.com/
Old Oct 22, 2015 | 04:16 PM
Whitefoot's Avatar
Whitefoot
Looks like
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0208 Injector Circuit Malfunction - Cylinder
P0113 Intake Air Temperature Circuit High Input
P0300 Random/Multiple Cylinder Misfire Detected.
There's no way all of my injectors could fail at once, right? At least not very likely I wouldn't think. But that would explain the misfires.
I've googled it and it says probably the injectors or harness. I just have a hard time believing that all of the injectors would go out at once
Old Oct 22, 2015 | 06:56 PM
Prismatic's Avatar
Prismatic
Originally Posted by Whitefoot
Looks like
Bad gas could be a possibility.
Old Oct 22, 2015 | 07:18 PM
p38251's Avatar
p38251
Tune up? Sea foam in the tank?
Old Oct 22, 2015 | 09:28 PM
Whitefoot's Avatar
Whitefoot
I thought it could be gas as well at first. I've filled up 3 times though and made sure to buy at 3 different stations. Other thought would be fuel filter.
I've also been smelling an odd smell when the truck is running.
No sea foam in the tank. Changed and gapped plugs about 6ish months ago. Have the new plug wires but haven't had the time to change them yet.
Old Oct 23, 2015 | 03:35 AM
Prismatic's Avatar
Prismatic
Like rotten eggs? Clogged cat is possible.
