Cruise control shutting off
Old Nov 2, 2015 | 03:50 PM
caveman1956's Avatar
caveman1956
Cool Cruise control shutting off
I turn on the cruise control and when I touch the SET button the light goes out and nothing happens. Before this it started to accelerate and not stop till the fuse burned out. I replaced the fuse and the circuit turns on. I reset the ECM. I replaced the the entire cruise control module and both switches / fuse is ok. What is left
Old Nov 2, 2015 | 05:07 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
Sounds like a bad wheel sensor. Mine did that after a hub replacement under warranty and the new sensor was bad.
Old Nov 2, 2015 | 05:14 PM
caveman1956
where is the wheel sensor located?
Old Nov 3, 2015 | 08:14 AM
Behind the wheel. Usually mounted to the hub.
Old Nov 3, 2015 | 01:19 PM
Heminaz's Avatar
Heminaz
I have a similar issue. My 2005 4x4 Ram Hemi 5.7 Cruise Control will shut off at 5MPH. If the vehicle is stopped or going very slow I can engage the cruise control but right at 5MPH the dash light goes out and will not come back on unless I go below 5MPH. I have pulled the steering wheel switches and hit them both with Contact Cleaner. I have a Superchips Flashpaq tuner that I set back to factory settings and then retuned back with corrected tire size as I am running 285x50x20 tires all around. There are no DTCs in the system. I have heard wheel sensor, clockspring, rear diff sensor are all possible causes. This a vacuum-less CC so it is not a leak. Can a wheel sensor go bad and still not throw a code? Any troubleshooting tips are appreciated before I just start replacing parts randomly at a cost I don't really have.
Old Nov 3, 2015 | 01:36 PM
p38251's Avatar
p38251
Left front wheel bearing. The wheel speed sensor which is part of the hub is bad.
