Bad Wheel Bearing, but feels tight?
Old Nov 3, 2015 | 11:08 AM
R0ADHEAD's Avatar
R0ADHEAD
Default Bad Wheel Bearing, but feels tight?
1500 Quad 4x4 Laramie 5.7L 140k, rusted frame and bed sides.
Truck isn't driven but on the weekends.
I had the passenger wheel bearing replaced 2 years ago during a road trip from TN to IN. The wheel was literally about to fall off.
This past weekend after about 30 minutes of driving, I started to hear the typical wheel bearing noise. Under braking I could really feel the vibration and hear it. It's most certainly on the drivers side front. It almost sounded like I was driving on the rumble strips on the side of the highway. I cut my trip short and headed home. I jacked up both fronts and did the wheel bearing test. No movement at all.
Has anyone ever had a failed wheel bearing with no visible symptoms?
Old Nov 3, 2015 | 01:34 PM
p38251's Avatar
p38251
Yes. They can be bad and have no play. Its not that bad. Yet.
Old Nov 4, 2015 | 06:48 PM
MikeHTally's Avatar
MikeHTally
Mine had no play at all. I did learn that if you turn the steering wheel from side to side at speed, you can hear the noise change. Mine went silent on a left turn, the noise was worse on a right turn.
Old Nov 9, 2015 | 10:14 PM
lxman1's Avatar
lxman1
Site Moderator
Mine had very little play, but sounded like I had Super Swampers on it. Roared like crazy.
