Test ride with rear drive shaft removed?
Old Nov 7, 2015 | 04:20 PM
cwells168's Avatar
cwells168
Default Test ride with rear drive shaft removed?
Anyone know if I can remove the rear drive shaft and cruise down the road in 4HI on 2004 Dodge Ram 1500 4x4 to try and pinpoint where I have a vibration?
I am reading that if I don't have a slip yoke, I can do it... not sure what I have in the transfer case. The transmission is the 545RFE auto.
Thanks.
Old Nov 9, 2015 | 09:46 PM
lxman1's Avatar
lxman1
Site Moderator
You can, but there is a possibility that fluid will run out since the yoke is not there to seal the output shaft.
