Fuel Pump brand recommendations
Old Nov 7, 2015 | 08:35 PM
CalDodge's Avatar
CalDodge
Default Fuel Pump brand recommendations
My pump went out exactly a year ago. I went online and bought an Airtex. Bad decision! The first one had a bad sending unit, the second one flat out didn't work, and the third was once again a bad sending unit. The company finally got fed up with me and they sent me a Spectra Premium. Everything worked perfectly for a year, but it just failed. The funny part is the pump motor works when its on its side but not upside down or right side up. I gave the motor a few thwacks with a wrench and now it works again. Piece of sh^t.
I know the motor is going to stop working again so my question is which brand should I got with next? I was looking at a Bosch, Carter, Delphi, or Denso. Any suggestions?
Old Nov 8, 2015 | 08:38 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Denso is most likely the OEM for the fuel pump. IIRC, from my 2nd Gen Days, Carter are as bad as Airtex.
Old Nov 8, 2015 | 09:53 AM
p38251's Avatar
p38251
If the rest of the assembly is good, why not replace just the pump. FASS or Airdog.
Old Nov 8, 2015 | 10:10 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Newer fuel pumps are a complete assy (sender + filter + pump). He'd be going through too much aggravation to tear apart the old unit to replace the pump motor.
