Dip stick error?
I just changed the oil on my new truck (05 Hemi), and after adding the correct amount of oil (7 quarts according to the manual), my dipstick reads 1/2 quart low. Anyone else have this problem?
ORIGINAL: Pwrwgn
ORIGINAL: osteodoc08
Just make absolutely sure it was on level ground and that you are getting a correct reading. Assuming that, just add what you need and keep an eye on it.
Let it drain back over night and check it in the morning. I'd venture to wager it will be closer to the full mark then.
It has to be a filter difference or dip stick issue or the capcity is a little more than 7 qts, which I doubt.
Trending Topics
It's not a problem, I wouldn't add more than 7 quarts. osteodoc08 is correct, it will be much closer to the fill line after sitting over night. 1/2 quart is not much oil and it will take quite a while for every drop to drain from all the internal components that have been coated.
Wait overnight. If it don't read full, add the 1/2 court. Is the Hemi pan a 7 qt pan? That means it needs 7 1/2 (7 in the pan, 1/2 in filte). I have an 8 qt on my Chevelle and need 8.5. Same way on all the cars I have ever changed oil on.
Chris
Chris
