Can you tell me the Difference
Old Jan 9, 2016 | 03:54 PM
GRed's Avatar
GRed
Default Can you tell me the Difference
Im planning to get a trans filter & gasket & fluid does it make a diff??
Ebay
Auto Trans Filter Kit PTC F-212 (Fits: 2008 Dodge Ram 1500 SLT 4.7L) 22.75 (flat & round filter) this one has gasket (I think rubber)
This one has gasket maker
>99-13 Jeep Dodge (4 Wheel Drive ONLY!!) Tansmission Filter&Sealer Kit OEM MOPAR (Fits: 2008 Dodge Ram 1500 SLT 4.7L) 51.00 (flat & round filter)
Pepboys--
Purolator Trans Filter (only flat no round filter) 17.99
TRANS FILPurolator Transmission Filter
Part # mpn PPL1271 SKU:9177066
Also does it matter on the trans fluid whether its supertech (walmart) or Pepboys proline, or autozone their brand? as
long as it's atf+4 do most if not all have the same properties??
Appreciate any input and help.
Thank you
Old Jan 9, 2016 | 06:06 PM
MikeHTally's Avatar
MikeHTally
WalMart's SuperTech has had pretty good reviews. I used Valvoline when I did mine. IMO, stay away from PepBoys and AutoZone. I've had bad dealings with both. You should get both filters.
Old Jan 10, 2016 | 10:46 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Idk mike, the filter I have in mine is from AZ and had it in for years although it's coming time to be changed. Last time I did it was around 60k and I'm just at 100k now but I also changed all 17 quarts out to Royal Purple.
Old Jan 10, 2016 | 12:05 PM
Black02CrCb's Avatar
Black02CrCb
you can go to http://www.cascadetransmissionparts.com. A very good buddy is the owner. Rob is his name, tell him Nathan from KC sent you. He will set you up with the best parts, and per your application whether it is towing or.. he is about as good as it gets, cheap prices, and all quality. He won't sell you crap.
Old Jan 10, 2016 | 12:37 PM
I've never had a problem with autozone.
