3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok here's the question. I've got an '05 with the separate key fob. Is there a way to use the newer keys where the key and fob are one unit on it? I have been through so many cases on my key fob I just figured there was a better way.
I have that folding key (aka Switchblade). Had to take it to a local locksmith so they could program the key to be recognizable by the PCM. Price will vary by location, but it has worked flawlessly in two years of use.
Could you post a link to that? I'd like to give it a try
Found it on ebay a ways back, don't have a link, just search like I did. It's an empty case, just get the key cut and transfer the battery and buttons intoi the empty case. Keep in mind I don't have SKIM, if you do you'll need some thing with a chip to be programmed.
