Down Size Rims
Old Jan 19, 2016 | 11:10 AM
thelaminator's Avatar
thelaminator
Default Down Size Rims
I have a 2004 Rumble Bee with 20" rims.
I want to put on a set of Mickey Thompson 315/75/16. The tires fit but the problem is the rims. Will they fit if I add a wheel spacer?
Old Jan 19, 2016 | 11:16 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
17" is as low as you can go due to the brake calipers. No way around that.
Old Jan 19, 2016 | 05:21 PM
JoshSlash87's Avatar
JoshSlash87
I actually disagree with this. When I put my new rearend in my truck I put an extra set of stock Ram 16" aluminum rims from my 97 ram on the old diff to roll it around on. I did have the calipers off, but the caliper mounts were still on. No issues what so ever.
I would say, all you can do is try it! and then if need be mod it a bit. I'll see if I can get a pic of it with an extra set of my calipers on, its buried in a snow bank at the moment.
Old Jan 19, 2016 | 09:11 PM
p38251's Avatar
p38251
Newer trucks have bigger brakes. 17 or 20 inch is what they come with.
Old Jan 19, 2016 | 10:53 PM
Hellkitten's Avatar
Hellkitten
I run 17" rims on my 03 dodge ram 5.7 hemi. I have a 3:55 tracloc rear it runs at around 1200rpms @ 50-55mph.
