RTV Gasket maker or gasket
Is there anything about carb cleaner that I shouldn't use, because I do have that instead of break cleaner. I was going to do it today but I think I will hold off 1 or 2 more days for warmer weather. Im planning to use plastic scraper and soft scouring pad use RTV which indicates apply around all bolt holes and mount plate torque 20ft lbs and wait hr then torque to 30ft lbs. I appreciate everyone's input
Thank you
gary
Thank you
gary
Once the cover is on, give it like 20 minutes for the perm to set up somewhat and then throw the gear lube in and you'll be all set, you can probably get away with filling it up right away with gear lube, but I like to let the permatex set a bit just for piece of mind before lube goes in, so after you get the cover on, clean up your area and put your tools away and by that time it should be ready to fill. Fill it up to the filler hole. It should be like 2 and a half quarts to fill it up to the filler hole. If you have a limited slip diff make sure to use 8oz of friction modifier, if not, just get the lucas 85/90 gear lube autozone sells or Wal Marts gear lube which is the cheapest lube you can get for around $4.50 a quart, I've had good luck with this stuff as well, I just use Lucas sometimes just to feel productive.
