Transmission Problem need help BAD!!
Old Jan 30, 2016 | 07:45 PM
pappy413's Avatar
pappy413
Default Transmission Problem need help BAD!!
I have a bit of a problem. Last week drove my truck home and parked. All was fine.
Next day it snowed a ton so I didn't drive it. Went out the next morning to go to work, truck won't move. Neither forward or reverse .CEL had a laundry list of codes P0700 P0876 P0736 P0731 P0732 & P0733. Did some research and checked the filter, it was split. Changed the fluid and filters, fired it up , reverse is fine and 1st and 2nd is fine tries to shift to 3rd and its like neutral. Now it has 2 codes P0700 and P0733. I could really use some info cause I don't need to throw more money at it if its done for..LOL
Old Jan 30, 2016 | 08:28 PM
p38251's Avatar
p38251
Fluid level correct?
Old Jan 30, 2016 | 11:15 PM
pappy413's Avatar
pappy413
I think so
Old Jan 31, 2016 | 02:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I don't think there is much else to check other than the valve body and possibly shift solenoids.
Old Jan 31, 2016 | 08:57 AM
pappy413's Avatar
pappy413
any transmission gurus here that might give direction to start first?
Old Jan 31, 2016 | 09:13 AM
MikeHTally's Avatar
MikeHTally
Doesn't sound good. What year/miles?
Old Jan 31, 2016 | 01:08 PM
pappy413's Avatar
pappy413
06 255k
Old Feb 1, 2016 | 11:28 PM
Black02CrCb's Avatar
Black02CrCb
filter was cracked? So is there any chance there is gunk in the filter screens in the valve body?
Old Feb 2, 2016 | 08:00 PM
pappy413's Avatar
pappy413
that's a possibility I guess that will be my next thing to try
Thanks
Old Feb 3, 2016 | 04:24 PM
dirtydog's Avatar
dirtydog
Moderate User
You said filter was cracked....The internal pan filter?
There is an external filter as well...
sounds like a pressure problem from clogged solenoids.
At this point, I would have a shop flush the fluid. Have them perform a powerflush. Again, I usually never recommend this type of flush but i bet it would unclog whatever is giving you grief.
