Hi, 04 Ram 1500 I am looking for the male Connector, the factory has this connector on the circuit board, I am trying to fix a set of after market tail lights so i need to hook the wires from Tail light into this connector so I then can plug it into the factory Harness on the truck.
I don't Need the Truck side but the light side.
Thanks
Thanks
Since the connector on the light side is built into the circuit board, you aren't going to find that avail in anything other than the circuit board
Spyder is sending me one, They said they found one laying around and are going to ship it out to me.
I had also spoke to recon and they said they could get me the harness, FYI just in case someone else has this issue.
The connector I have seen is literally soldered in the board so this is interesting if someone makes something aftermarket or have a part number for an oem
