Only starts when i remove the oil cap?
Old Feb 19, 2016 | 05:24 PM
p38251's Avatar
p38251
Compression check?
Old Feb 19, 2016 | 05:31 PM
Silasmyboy's Avatar
Silasmyboy
fouled meaning what? They bad? cause both of them before the cat look like that
Old Feb 19, 2016 | 05:40 PM
Silasmyboy's Avatar
Silasmyboy
Compression test haven't done yet, does it matter what plug I test it on? Trying now
Old Feb 19, 2016 | 06:53 PM
Silasmyboy's Avatar
Silasmyboy
Well I pulled the first spark plug (driver side) towards the grill an there was metal shards on the tip of it an no compression coming from that cylinder, if I did it correctly I pulled power connectors to all coil packs 4 each side an pulled 4 plug wires on each side removed the first plug an nothing on the gauge. Not sure if I did it correctly please someone help me with this headache of mine. Thank you guys for taking the time to respond when you can I really appreciate it.
Old Feb 19, 2016 | 08:29 PM
p38251's Avatar
p38251
Try the next cylinder. Metal of the plug is usually an ominous sign.
Old Feb 20, 2016 | 04:34 PM
JoshSlash87's Avatar
JoshSlash87
One thing that happened to my 97 360 magnum was the cat plugged and the truck sounded real quiet and I could only hear the belt & pulleys running. Punched the cat out and reinstalled it and it still runs great!. It being plugged did blow my valve seals out.
Old Feb 20, 2016 | 07:43 PM
p38251's Avatar
p38251
Don't jump all over the place. Do a full compression check. Go from there. You wasting time and maybe money. Guessing and jumping from what if to what if.
Old Feb 20, 2016 | 10:56 PM
JoshSlash87
Totally agree with you!
Old Feb 21, 2016 | 08:06 AM
This. Troubleshoot methodically. Eliminate obvious, simple things first. Compression check will isolate the problem.
Old Feb 22, 2016 | 02:55 PM
JoshSlash87
Make sure you only take ONE plug out per cylinder and replace that spot with the compression tester!. Don't take both out or you'll have NO compression!
